Message d"erreur après reinstallation JSR
jesus851
Messagepar jesus851 » 26 août 2015 20:03
Salut à tous
pourriez vous SVP m'aider, voici ce que me donne JSUNNYREPORTS.cmd
C:\Users\jésus\Desktop\jsunnyreports1.4.0.0final>java -jar JSunnyReports.jar
jSunnyReports. Copyright : 2009-2013, Martin Kleinman, Martijn van der Pauw & Ba
stiaan Schaap, version 1.4.0.3final Codename 'Snowflake'. Builddate : 25-08-2013
at 11:30
jSunnyReports. The solar equivalent of the Swiss knife!
Check out http://www.jsunnyreports.com for the latest version.
Loaded: filecache.jsun
Loaded: inverterdata.jsun
Reading cached files
Loading and sorting data
Processing inverterdata for : SB3000TL
cache hit for C:/Users/jÚsus/Documents/SMA/Sunny Explorer/Mon installation photo
volta´que...-20150626.csv but fileSize differs, going to reload
Fatal error, this error should not have occured, mail info@jsunnyreports.com abo
ut this error!!
Class: nl.mk.jsunnyreports.dataloaders.SunnyExplorerDataLoader Method: csvDetail
FileRemove. Line: 280
Class: nl.mk.jsunnyreports.dataloaders.SunnyExplorerDataLoader Method: loadCSVFi
les. Line: 336
Class: nl.mk.jsunnyreports.dataloaders.SunnyExplorerDataLoader Method: dataLoade
r. Line: 368
Class: nl.mk.jsunnyreports.dataloaders.LoaderProgram Method: readInverterData. L
ine: 385
Class: nl.mk.jsunnyreports.JSunnyReports Method: main. Line: 174
java.lang.NullPointerException
at nl.mk.jsunnyreports.dataloaders.SunnyExplorerDataLoader.csvDetailFile
Remove(SunnyExplorerDataLoader.java:280)
at nl.mk.jsunnyreports.dataloaders.SunnyExplorerDataLoader.loadCSVFiles(
SunnyExplorerDataLoader.java:336)
at nl.mk.jsunnyreports.dataloaders.SunnyExplorerDataLoader.dataLoader(Su
nnyExplorerDataLoader.java:368)
at nl.mk.jsunnyreports.dataloaders.LoaderProgram.readInverterData(Loader
Program.java:385)
at nl.mk.jsunnyreports.JSunnyReports.main(JSunnyReports.java:174)
Done processing ( time used : 460ms ), exiting program.
C:\Users\jésus\Desktop\jsunnyreports1.4.0.0final>pause
Appuyez sur une touche pour continuer...
bidulechou
Re: Message d"erreur après reinstallation JSR
Messagepar bidulechou » 26 août 2015 23:00
Bonjour jesus851,
Quand tu dit "reinstallation JSR", qu'as tu fait exactement ?
jesus851
Messagepar jesus851 » 27 août 2015 07:56
Après formatage windows 7, nouvelle installation complete de Sunny explorer et JSR 1.4.0.O car je n'ai rien compris à la nouvelle version 1.6 ( je n'ai pas trouvé le fichier config.cmd).
Doudy
Messagepar Doudy » 27 août 2015 08:45
Il me semble que maintenant il n'y a plus de config mais que tout se trouve dans setting.ini
Inverters.conf est également totalement modifié.
Courage...
bidulechou
Messagepar bidulechou » 27 août 2015 19:17
Oui, je confirme : il n'y a plus d'interface graphique de configuration à partir de la version 1.6 de JSR.
Mais, on retrouve dans diary.ini, summary.ini, settings.ini et inverter.conf toutes les infos qu'on saisissait à l'écran.
Et de toute façon, config.cmd ne faisait que présenter des champs à saisir pour, à la fin, écrire les infos dans les fichiers ci-dessus.
Donc, il est assez facile de passer à la version 1.6 en étudiant les fichiers de la version 1.4.
Pour en revenir au pb de jesus851, lorsque tu as lancé JSR re-installé, est-ce qu'il y avait les fichiers .jsun de la version précédente ou pas ?
Est-ce que le fichier qui as un pb existe bien sur le disque ? celui qui a la date du 26/06/2015 suivi du .csv ?
Tu pourrais essayer de supprimer les fichiers .jsun, de sauvegarder tes fichiers issus de l'onduleur dans un répertoire ailleurs, puis de ne laisser qu'un fichier de données et voir si tu as le même souci.
