Remise en route difficile suite carsh PC
thekite59
BDPV : thekite59
Departement/Region : 62
Messagepar thekite59 » 04 mars 2012 17:25
Salut a tous comme le titre le dit mon pc a crashé
Je vai essayer de donner un Max de d'infos pour ceux qui pouraais m'aider
JSR:jsunnyreports1.3.1.4Lightning
Quand je lance le fichier jsunnyreports ca donne :
F:\Documents and Settings\thekite59\Bureau\Solaire 2012\jsunnyreports1.3.1.4Ligh
tning>java -jar JSunnyReports.jar
jSunnyReports. Copyright : 2009-2011, Martin Kleinman, Martijn van der Pauw & Ba
stiaan Schaap, version 1.3.1.4 Codename 'Lightning'. Builddate : 09-12-2011 at 1
1:00
jSunnyReports. The solar equivalent of the Swiss knife!
Check out http://www.familie-kleinman.nl/jsunnyreports for the latest version.
Loaded: filecache.jsun
Loaded: inverterdata.jsun
Reading cached files
Loading and sorting data
Processing inverterdata for : thekite59
Generating all the graphs and html files.
Generating all sorts of graphs
Created a total of 0 GraphYearsRenderer graphs in : 16 milliseconds. (0 average
Created a total of 0 GraphYearRenderer graphs in : 0 milliseconds. (0 average )
Created a total of 0 GraphInverterYearRenderer graphs in : 0 milliseconds. (0 av
erage )
Created a total of 0 GraphMonthRenderer graphs in : 0 milliseconds. (0 average )
Created a total of 0 GraphInverterMonthRenderer graphs in : 0 milliseconds. (0 a
verage )
Created a total of 0 GraphDayRenderer graphs in : 0 milliseconds. (0 average )
Created a total of 0 GraphKWHDayRenderer graphs in : 0 milliseconds. (0 average
Created a total of 0 GraphActualRenderer graphs in : 0 milliseconds. (0 average
empty value returned for system.latitude
Created a total of 0 GraphTopDayMonthRenderer graphs in : 0 milliseconds. (0 ave
rage )
Created a total of 0 GraphInverterRenderer graphs in : 0 milliseconds. (0 averag
e )
Created a total of 0 GraphkWpRenderer graphs in : 0 milliseconds. (0 average )
Created a total of 0 GraphForumSignatureRenderer graphs in : 0 milliseconds. (0
average )
Generating all JS Files for Sonnenertrag.eu.
Generating all HTMLfiles
Could not write stylesheet.css please check your pathnames in your settings.ini
file
Could not write index.html please check your pathnames in your settings.ini file
Could not write diary.html please check your pathnames in your settings.ini file
Generating all the Record tables and html files.
Generating record tables + html files
Could not write records_2010.html please check your pathnames in your settings.i
ni file
Could not write records_2011.html please check your pathnames in your settings.i
ni file
Could not write records_2012.html please check your pathnames in your settings.i
ni file
Could not write records.html please check your pathnames in your settings.ini fi
le
FTPTransfer
Connecting to ftpperso.sfr.fr With username thekite59.perso.sfr.fr
Backup Transfer
Writing: filecache.jsun containing 587 files
Writing: inverterdata.jsun
Done processing ( time used : 2860ms ), exiting program.
tning>pause
Par avance merci
pepe69
BDPV : pepe69
Re: Remise en route difficile suite carsh PC
Messagepar pepe69 » 04 mars 2012 18:18
Vérifie ce que tu as comme repertoire dans le setting.ini valeur "basic.outputlocation=", c'est la que jsr va mettre les fichiers générés avant upload sur le WEB.
Delete les 2 fichiesr ".jsun" pour qu'il reparte sur des bases saines (filecache.jsun et inverterdata.jsun)
koi-2-9
BDPV : PV_BZH
Messagepar koi-2-9 » 05 mars 2012 19:43
j'ai déplacé le souci de vlb06 ici : viewtopic.php?f=79&t=24970
(chacun son sujet :lol: )
The Kite : pépé69 a raison, tu as surement paramétré un répertoire inexistant dans config.ini
thekite59
BDPV : thekite59
Messagepar thekite59 » 07 mars 2012 18:42
Alors les gars je suis deg ca ne marchais pas car mon disuqe a lettre F au lieu de C donc je l'ai changée dans le fichier setting.ini et pour l'instant ca prend troi siecel car il telecharge tout depuis mi 2010
koi-2-9
BDPV : PV_BZH
Messagepar koi-2-9 » 07 mars 2012 19:21
thekite59 a écrit :Alors les gars je suis deg ca ne marchais pas car mon disuqe a lettre F au lieu de C
C'est Fhiant ! :lol:
thekite59
BDPV : thekite59
Messagepar thekite59 » 07 mars 2012 19:27
Tu m'etonne surtout pour une connerie pareille, par contre c'est quoi le tbt sur mon site car j'ai une courbe bizarre
vlb06
BDPV : limelli
Departement/Region : 06
Messagepar vlb06 » 07 mars 2012 19:33
Tbt correspond au graphique de rayonnement , mais je ne sais pas comment il est créé ,chez moi il a une courbe bizarre :D
bidulechou
Messagepar bidulechou » 07 mars 2012 20:57
Pour avoir une courbe "normale", il vous suffit de remplacer la chaine tbt (qui veut dire en fait "to be translate" en anglais, soit "A traduire" en français) par sa traduction française dans le fichier French.ini (répertoire templates)
Attention, cette chaine tbt apparaît à plusieurs endroits.
Pour ma part, j'ai mis :
Code : Tout sélectionner
graphs.degrees    = Degrés
graphs.sunheighthorizon = Hauteur du soleil à l'horizon
graphs.anglewithpanels = Angle avec les panneaux
graphs.radiationcurve = Courbe de rayonnement
graphs.maxheightsun = Hauteur maximale du soleil
graphs.minheightsun = Hauteur minimale du soleil
html.on           = le
index.radiation          = Rayonnement
vlb06
BDPV : limelli
Messagepar vlb06 » 07 mars 2012 21:57
Merci bidulechou , la courbe est correcte maintenant . :sun:
thekite59
BDPV : thekite59
Messagepar thekite59 » 08 mars 2012 16:37
Merci pour l'aide JSR marche maintenant par contre je n'arrive plus a faire marchait le script quelqu'un en aurai t'il un qui marche avec le dernier SE avec les fichier en SX2 au lieu de SXP
Merci d'avance
pepe69
BDPV : pepe69
Messagepar pepe69 » 08 mars 2012 21:46
C'est cela que tu cherches :?
rem ***** récupération de la date du jour *****
for /F "tokens=1-4 delims=/- " %%a in ('date/T') do set DATE=%%d%%c%%b%%a
setLocal EnableDelayedExpansion
rem **** Initialisations
set /a TODAY = DATE
set fichier=Photovoltaique_PP
set StockageFichiers=E:\jSunnyReports\Donnees
set SE=C:\Program Files (x86)\SMA\Sunny Explorer\
set FichierInstallation="C:\Users\Patrick\Documents\SMA\Sunny Explorer\Photovoltaique_PP.sx2"
echo ***** récupération de la date du dernier fichier *****
echo off
cd /D %StockageFichiers%
rem ***** ci dessous, en 2020, il faudra changer |find "201" par |find "202"  ******
for /f "tokens=2 delims=-" %%a in ('dir /b *.*') do (
echo %%a|find "201" > nul
if errorlevel 0 (
set datelast=%%a
)else (
set datelast=%DATE%)
echo on
set datelast=%datelast:~0,8%
rem ***** ***** ***** ***** ***** *****
set fichier=%fichier%-%DATE%.csv
rem  ***** comptage nombre de lignes fichier du jour *****
set lignes=0
for /f %%a in ('find /v /c "" ^< %fichier%') do set /a lignes=%%a
echo Il y a %lignes% lignes dans le fichier %fichier%.
rem  ***** lancement SunnyExplorer pour récupérer tous les fichiers depuis le dernier traité *****
cd /D %SE%
SunnyExplorer %FichierInstallation% -userlevel user -password 0000 -exportdir %StockageFichiers% -exportrange %datelast%-%TODAY% -export energy5min
set lignes2=0
for /f %%a in ('find /v /c "" ^< %fichier%') do set /a lignes2=%%a
rem *************@echo Il y a %lignes2% lignes dans le fichier %fichier%.
rem  ***** si nombre de lignes différents, on met à jour le web, sinon, rien *****
if %lignes%==%lignes2% goto fin
rem  ***** lancement JSunnyReports pour maj Web *****
cd /D E:\jSunnyReports\
jsunnyreports.cmd
rem  ***** lancement export des données sur site web via ftp pour save 2 fois par mois *****
set JOUR=%DATE:~0,2%
if "%JOUR%"=="14" ftp -v -s:E:\jSunnyReports\data.ini
if "%JOUR%"=="28" ftp -v -s:E:\jSunnyReports\data.ini
:fin
Bon, il convient de remplacer toute ma config par la tienne
Modifié en dernier par pepe69 le 09 mars 2012 22:10, modifié 1 fois.
thekite59
BDPV : thekite59
Messagepar thekite59 » 09 mars 2012 20:35
Je cherche le fichier pour lancer SE et qui enregistre automatiquement la production du jour et apres lance JSR.
Car le fichier que j'avais avant ne marche plus avec le nouveau SE et le fichier en SX2
pepe69
BDPV : pepe69
Messagepar pepe69 » 09 mars 2012 22:09
Oui, c'est bien ce que je t'ai mis en ligne, il faut juste adapter les entrées suivantes a ta config
et
cd /D E:\jSunnyReports\jsunnyreports.cmd
Et coller le tout dans un fichier que tu nomme comme tu veux en .cmd puis le lancer quand tu veux, une foius ou plusizures fois par jour, une fois par semaine, ou une fois par mois, il reprendra tous les fichiers manquants depuis le dernier passage
Je me suis rajouté a la fin un ftp sur mon site WEB pour sauvegarder les données en entrée 2 fois par mois (ca peut servir en cas de crash)
thekite59
BDPV : thekite59
Messagepar thekite59 » 14 mars 2012 15:56
Merci pour toute l'aide mon site remarche correctement et les mises ajour du site aussi donc que du bonnheur.
