1.3.2.0Storm is finished
jsunnyreports
Departement/Region : FL
Messagepar jsunnyreports » 01 févr. 2012 17:25
I just wanted to let everyone know that I fixed the last two nasty bugs today in the SunRadiationGraphs.
That leaves the user manual to be rewritten.
I will try to make a beta release this friday ( without the manual ) I will not make it publically available until the manual is finished but if anyone is interested drop me an e-mail on friday :)
By the way:
This is the list of fixed bugs/features:
jSunnyReports - 1.3.2.0Storm (Not Yet Released) [ View Issues ]
Storm bugfix release.
- 0000218: [Bug] Sun Radiation graph sometimes renders wrong ( color scheme of graphs ) (windfreak) - resolved.
- 0000243: [Bug] with negative latitude the radioncurve is drawn negative instead of positive (windfreak) - closed.
- 0000284: [Bug] Third year costs are equal 0 (Martin) - closed.
- 0000286: [Enhancement] Add -updateCosts as parameter (Martin) - closed.
- 0000208: [Idea] Add update interval for index.html to the configurationtool ( in minutes ) (Martin) - closed.
- 0000252: [Idea] Add support for Sunny Webbox Bluetooth ( dataloader ) (Martin) - closed.
- 0000293: [Enhancement] OK4E loader cannot handle multiple inverters in one file (Martin) - closed.
- 0000292: [Enhancement] Add updated Soladinlogger with readme to /extras (Martin) - closed.
- 0000291: [Enhancement] Add Arduino sketch to jSunnyreports / extras (Martin) - closed.
- 0000257: [Idea] Add Arduinologger source to jSunnyreports project ( / extras ) (Martin) - closed.
- 0000225: [Idea] Add support for Schüco sunanalyzer files. (Martin) - closed.
- 0000290: [Enhancement] Remove backup engine from the project (Martin) - closed.
- 0000289: [Refactoring] Update FTP code, use fileFilter to filter out files that need to be uploaded (Martin) - closed.
- 0000253: [Idea] Add support for Aurora One power inverter ( communicator ) Dataloader (Martin) - closed.
- 0000276: [Refactoring] Modify all dataloaders. create a seperate methodHandler for all filetypes (Martin) - closed.
- 0000287: [Refactoring] Check for inverter options is done in the dataloader instead of the loaderprogram (Martin) - closed.
- 0000232: [Idea] Ignore invalid data when read instead of crashing (Martin) - closed.
- 0000282: [Bug] When a directory does not exist and the scheduler is used it will generate lots of stacktraces (Martin) - closed.
- 0000261: [Refactoring] Refactor dataloaders. Lots of double code. InverterLoaderFactory? (Martin) - closed.
- 0000281: [Bug] kWhGraph are missing (On version 1.3.1.4) (Martin) - closed.
- 0000238: [Display issue] Problem with TBT (Martin) - closed.
- 0000254: [Bug] There is a bug in the Sunnybeam BT dataloader ( SB 2500 HF ) (Martin) - closed.
- 0000260: [Refactoring] Update OpenCSV library to latest version. (Martin) - closed.
- 0000280: [Enhancement] Modify cache mechanism for SB SDC users , cache is effectively disabled at the moment (Martin) - closed.
- 0000274: [Bug] SunnybeamBT dataloader doesn't notice begin and end of day correctly (Martin) - closed.
- 0000204: [Bug] Night 0 not ignored for SunnyBeam (Martin) - closed.
- 0000275: [Refactoring] Refactor filefilter now inline should be an external class (Martin) - closed.
- 0000279: [Refactoring] Refactor how the reportproperties are handled. (Martin) - closed.
- 0000278: [Refactoring] Refactor how languages are handled. (Martin) - closed.
- 0000255: [Bug] Problem with Tim van Haudt his data. Sunny Explorer contains data but is not loaded. (Martin) - closed.
- 0000277: [Refactoring] Refactor dataloaders, remove all inline FilenameFilter classes (Martin) - closed.
- 0000273: [Refactoring] Refactor dataloaders, manual.xls load should be identical for all dataloaders. maybe in parent class? (Martin) - closed.
- 0000272: [Bug] Difference between yield between 1.3.1.4 and Storm. Some files seem to be ignored (Martin) - closed.
- 0000267: [Refactoring] Remove FTPIgnore from the project entirely ( config tool / files ) (Martin) - closed.
- 0000259: [Refactoring] Update commons.net ftp client to 3.0.1 (Martin) - closed.
- 0000270: [Refactoring] Refactor cache Modification. set modification can be moved to add and subValues. (Martin) - closed.
- 0000265: [Bug] Discrepancy in loading data between 1.2x and 1.3x. 1.2x giving the right sum. 1.3.x 260kWh too low. (Martin) - closed.
- 0000271: [Refactoring] Adding and substracting values in cache mechanism don't go well ( 1 + 1 = 2.. 2 - 1 != 1. ) (Martin) - closed.
- 0000264: [Bug] "Empty String" error right after saving the actual graphs. (Martin) - closed.
- 0000269: [Bug] FTP issue, NPE while traversing directory (Martin) - closed.
- 0000258: [Refactoring] Remove FTPIgnore from jSunnyreports (Martin) - closed.
- 0000250: [Bug] Sunny Explorer would sometimes give a array out of bounds exceptions when loading data (Martin) - closed.
[42 issues]
Re: 1.3.2.0Storm is finished
Messagepar ericg » 01 févr. 2012 19:27
Yes! Support for Sunny Webbox! I will beta test it with pleasure!
bennoz44
BDPV : bennoz44
Messagepar bennoz44 » 01 févr. 2012 21:33
Great piece of news !
Beta testing for Sunny Explorer (SMA SB300TL, bluetooth) if you need...
Doudy
Messagepar Doudy » 02 févr. 2012 08:26
Yes ok for beta testing for Sunny Boy 3800 (Sunny Data Control) + Sunny Beam no bluetooth.
jsunnyreports
Messagepar jsunnyreports » 03 févr. 2012 16:29
Update, the first version of 1.3.2.0Storm is ready, including an updated manual.
I'm actually looking for beta testers at the moment. Please drop me an e-mail and I will send you the download link. I want to fix the last few bugs that are in there and then release it.
gridained
BDPV : gridained
Departement/Region : Aube
Messagepar gridained » 11 févr. 2012 17:40
Marche parfaitement pour moi !
attention toutefois si vous aviez rentré comme moi un chiffre à virgule pour le kWh/kWp dans la configuraton de l'onduleur cette version Storm ne semble prendre qu'une valeur entière.
Il ne me reste plus qu'a refaire tout mon design personnel !
This Version work perfectly for me !
Make attention ! If like me you put an kWh/kWp data with a coma, you may experience an error : Storm version seems only able to take some integer data for this parameter.
it's time now for me to remake my design by modifying templates
crashgarrett
BDPV : crashgarrett
Messagepar crashgarrett » 13 févr. 2012 17:03
mise à jour réussi :)
MaxLan
BDPV : maxlan
Messagepar MaxLan » 13 févr. 2012 22:19
Ok pour moi aussi en 1.3.2.0 et je confirme les dire de gridained concernant le chiffre à virgule dans kWh/kWp dans la configuration de l'onduleur
14xSanyoHIP-214NKHE5 (bac Zinc), Onduleur Wagner & Co 3000tl20 (Sma) Sud -80, Pente 45°
Mon suivi de production JSunnyReports: http://maxlan35.pagesperso-orange.fr/jsunnyreports ou http://maxlan35.pagesperso-orange.fr/jsunnyreports2
crashgarrett
BDPV : crashgarrett
Messagepar crashgarrett » 25 févr. 2012 19:41
crashgarrett a écrit :mise à jour réussi :)
nickel sauf .....
les débuts et fins de graphe ne commence pas à zéro !!!
et vous ?
gridained
BDPV : gridained
Messagepar gridained » 25 févr. 2012 20:02
Je n'ai pas ce problème !
voir peut être du coté des fichiers sources de données, pour ma part des csv venant d'un Sunny Beam BT
crashgarrett
BDPV : crashgarrett
Messagepar crashgarrett » 25 févr. 2012 21:38
gridained a écrit :Je n'ai pas ce problème !
cela fonctionnait bien avant cette version aussi bien pour le graphe que pour le voyant de production crête , il y a quelque chose à modifier ?
gridained
BDPV : gridained
Messagepar gridained » 26 févr. 2012 09:16
rien a modifier !
ta journée d'hier fini bien par 0
Doudy
Messagepar Doudy » 26 févr. 2012 09:21
En janvier tes journées ne commençaient pas à zéro non plus!.
Ce serait plutôt une vérification à faire au niveau de ton input de données.
pepe69
BDPV : pepe69
Messagepar pepe69 » 26 févr. 2012 11:37
Installée hier au soir la 1320 et fait marche arriere car il me manquait plein de dates et des mois vides sur 2011. Réinstall ce matin a tete reposée et pareil, j'ai avril, mai 2011 complètement vide, juin ou suel 2 jours remontent ...... J'ai regardé au moment de la generation (les logs) et apriori rien de probant.
Quelqu'un aurait il eut ce soucis ou a une idée :?:
Je refais marche arriere
gridained
BDPV : gridained
Messagepar gridained » 26 févr. 2012 13:10
question bête, peut-être ?
Avez-vous pensez à enlever les deux fichiers de cache ? *.jsun
la régénération est longue, mais je n'ai eu aucun problème
on n'est pas assuré de la compatibilité du cache entre les versions !
pepe69
BDPV : pepe69
Messagepar pepe69 » 26 févr. 2012 18:12
Ben effectivement, la premiere fois il me semble ne pas avoir delete ces fichiers mais lors de l'install de ce matin je suis repartit tout propre donc sans rien et la remonté WEB FTP a durée une éternitée.
Le pb n'est donc pas là, une autre idée :?:
philip05
Departement/Region : 05
Messagepar philip05 » 27 févr. 2012 00:45
Le passage en 1.3.2.0 s'est bien passé de mon côté :D
Merci à Martin & Co d'avoir ouvert JSR aux utilisateurs d'onduleurs inadaptés aux versions précédentes :idea:
Je n'ai pas constaté de "bug" pour l'instant ;)
Je n'ai pas vu l'onglet de configuration "source files backup" dans config.cmd :!: Où les données vont-elles se sauvegarder sur le FTP :?:
Quel ensoleillement ce mois de février :!:
:sun: :sun: :sun:
gridained
BDPV : gridained
Messagepar gridained » 27 févr. 2012 08:36
Où les données vont-elles se sauvegarder sur le FTP ?
Martin a fait un petit sondage, et il s'est avéré que l'option allait être retirée !
Donc pour la version 1.3.2 c'est chose faite, il n'y a plus de backup des données vers le ftp !
jacky 34
Messagepar jacky 34 » 27 févr. 2012 16:43
bonjour à tous.
mise en place de la version " 1.3.2.0 et tout me semble correct
:sun: :sun:
Membre du Image
crashgarrett
BDPV : crashgarrett
Messagepar crashgarrett » 27 févr. 2012 19:39
gridained a écrit :rien a modifier !
pas pour moi , ou alors tu a regarder quand j'ai essayer avec l'ancienne version , je crois que je vais y retourné :roll:
