strange phenomena is PV output
JensenBreck
BDPV : no
Departement/Region : usa
Professionnel PV : manufacturer-install
Messagepar JensenBreck » 02 nov. 2017 09:02
Hi,
I have 16 sunpower 318 panels connected to sma smc5000a (inTL) inverter (2 strings of 8 panels each).
Each panel has also Tigo optimizer. Tree weeks ago, my inverter started issuing "MPP/insulation warning messages", and the red light (ground fault indication) was turned on. At the same time exactly, I strated to witness a decrease in the output of the system - a strange phenomena could be seen in the Tigo monitoring:
In both strings, roughly speaking, the last panels are producing significantly smaller output then the first panels.
Yesterday, the positive grounding kit of the inverter was replaced, and indeed the red light is off, and no more warning messages are issued by the inverter.
However, the output of the system, as shown by the Tigo monitoring, shows exactly the same strange phenomena. Needless to say - the phenomena is seen in completely unshaded conditions for all panels.
Does anyone has any idea what happend in my system?
Thanks.
I didn't find the right solution from the internet.
References:
https://www.altestore.com/forums/index. ... 663.0.html
infographic video
Re: strange phenomena is PV output
Messagepar flen42 » 02 nov. 2017 11:18
i have the same answer than tom M on https://www.altestore.com/forums/index. ... 663.0.html
check connections between panels , it must be a earthing leakage
thanks to the Tigo optimizer you may know easily were is the problem
Hari43
Messagepar Hari43 » 02 nov. 2017 17:52
Le British au secours !!!
Messagepar flen42 » 02 nov. 2017 18:01
ok mon angliche est pas des meilleurs
mais si on peut aider un américain pourquoi pas !
Hari43
Messagepar Hari43 » 02 nov. 2017 20:27
D'autant plus que chez eux, depuis quelques mois, ils ne sont pas aidés...
